Forgive me, but this is going to be very hard to explain without any pictures...
I'm wondering if anyone reading this who's purchased AGR Performance's Ford Rack and Pinion was able to reuse the stock steel insert that the old rack and pinion mounted on. It's what goes through the frame and sticks out about 3 inches for the rack to mount on. The bolt is fed through this insert and then a washer and nut go on the other end to secure the rack. There is almost no play in the bolt if any at all.
The AGR performance Ford rack and pinion comes with polyurethane bushings and a steel insert that goes from one end of the bushing to the other, but not through the frame. I called them and they told me to just use the bolt, and trash the stock insert. I'm worried about way to much play without that steel insert going through the frame. The bolt diameter is about .465 inches, the frame hole without the steel insert is about .76 inches, and the diameter of the steel insert on the agr rack is about .645 inches.
I'm sure I can get it tight to the frame, but it would only be a matter of time before it starts slipping around. I don't want my steering shifting around on me while I'm driving down the road, and I'm sure nobody else would either. Can anybody please help?
