Why do people go for the 5lug setup over the stock 4?
Dead sexiness.
And the 4 lug is extremely suspect once you get above 400 whp on slicks from what I hear. Anyone remember Underpressure GT (Joe) and his 4 lug incident?![]()
Better wheel selection and you have the ability to run some NICE OEM brakes (the 13"/11.65" Cobra setup) for dirt cheap without having to shell out $3000 for one of those kits.
Tell me where to find these! LOL I'm looking for bigger brakes as we speak, and I'm not willing to shell out the cash for Baer/Wilwood/FMS Cobra R stuff. 2000 for just front rotors/calipers is ridiculous.
Well if you want brand new stuff, check out www.buyfordracing.com
Their cheapest 13" kit is $310 for the Mach 1 kit (what i have on my GT) and it comes iwth new rotors, loaded calipers and SS lines. All you would need then for the front would be the spindles (approx $100/pair) and the adapter for the pass line SS line ($5) and your front conversion is pretty much all set.
Out back they sell the M-2300-M kit for $175. You would also need a pair of 94-98 SN95 axles ($50 or so) and a set of calipers ($200ish new or $50ish used). Toss in some 94-95 rear softlines ($50) and the adapters ($10) and that's the rear conversion.
Then you just need the MC, Booster, 3-2 conversion, prop valve plug and adjustable prop valve and you are good to go. There are other little odds and ends but that's the majority of the Cobra kit. If you go used you can even get it cheaper.
Don't use what i wrote as a guide to the install though, do some research here
www.sn95brakes.com
Dead sexiness.
the M2300K kit (whole shootin match) is $21xx on buyfordracing...once you get the MC, booster, etc you are talkin decent $$
I also bought my car with a suspension upgrade. It has the stock size tires, and they rub on the fenders around sharp turns. Do you think the Cobra setup will fit?
