why 5 lugs?
hm that sounds like its about as low as mine is, maybe a little lower. the only reason i tuck the top of my tire is because the tires are a bit too tall...you are tucking stockers somewhat...where does the rub occur? fender extension or on the inside of the wheelwell?
to answer your question about the cobra setup, though, you will need at least 17" wheels to clear the cobra brakes. run a 245/45/17 tire and if you rub on the fender extension, you will still rub there unless you convert to 91-93 fenders. if the rub is on the inside, one option is to change to SN95 control arms which have a wider track than the foxes, and should get you away from your rub on the inside of the wheelwell (if thats where the rub is occuring)
Sorry Mustang5L5, I should have been more specific. My car is already converted to 95 Cobra (front) and 95 GT (rear) brake specs. I'm looking for 2-4 piston calipers and big slotted rotors.
Thanks for the link though! :SNSign:
