I have always wondered why they did this, haven't been able to find an answer. Does anyone know?
Is it for better balance or something?
Yes, this is the reason I have always heard also. Think about it, with the firing order 1-5-4-2-6-3-7-8 the first main bearing is loaded by two consecutive pistons firing one right after the other with the harmonic balancer right there to take the shock....with the 1-3-7-2-6-5-4-8 this loading is transferred to the rear main journal with has much more support and is balanced by the flywheel/clutch or torque converter assembly. Now I do not have the specifics to why this arrangement is better, but according to Ford the latter firing order is much easier on the crankshafts. All I know is I did snap the snout off of the crank in the Shelby many years ago, it broke right behind the #1 jounal....luckily the damage to the block was minimal and repairable.D.Hearne said:I've always read that it was done to revise the loading on the main bearings.
Ronstang said:You will not notice it without mufflers, but through the exhaust I can tell the difference between an early 302 and a late model HO 302 just by listening. It may be just me but others I know have confirmed that there is a different sound. It is also not as noticeable at idle but more so at speed.
Even with the mufflers both mine sound the same. The difference you may be hearing may just be the design of the exhaust system. I know that there's a difference in sound with an X pipe as opposed to an H pipe, and another without any crossover.Ronstang said:You will not notice it without mufflers, but through the exhaust I can tell the difference between an early 302 and a late model HO 302 just by listening. It may be just me but others I know have confirmed that there is a different sound. It is also not as noticeable at idle but more so at speed.
That theory doesn't hold water, in the 5.0> H.O. cylinders 5 & 6 fire consecutively instead of 7 & 8.Max Power said:I do remember that in older cars with equipment falling into disrepair, having the 7 and 8 cylinders firing side by side, older plug wires would sometimes bleed into each other. I was always taught to route the 7 and 8 plug wires on opposite side of the loom from each other.
Hey, even you have great knowledge to share too-------- don't stopHistoricMustang said:I continue to be amazed at the amount of knowledge here at StangNet.
D. Hearne and some of the others are simply fantastic and I only wish to someday be in that bracket. I can not even count to 8 and they are discussing five firing next to six and seven next to eight.
Great stuff.
HistoricMustang
www.historicmustang.com
