Why did this happen installing my lower intake?
pwcracer
347
Hastings, MN, USA
Why did this happen installing my lower intake? (Update)
I did everything like I was told, I had the fel pro gaskets tacked in to the heads, I had a 1/4 inch tall bead of RTV on the ends, and I was torquing down the bolts in the specified order. I first went to 1 foot pound, then 13, then 25 to finish it. When I got the the bolt to the right of the dizy, (Front right corner) the stupid bolt broke off in the head before I hit my torque reading! I pulled the intake off and another thing I thought was funny is that the RTV in the ends looks as though it was never touched, there was none on the intake either.. Now I have to e-z out the bolt if I can, and buy new bolts, I think I will go with the strongest grade bolt I can find.
If i ever get this resolved, do I have to use new intake gaskets?
It is a good idea to replace the intake bolts as they corrode from the water passages and such like mentioned. I would get some ARP's, they are around $25 but well worth it IMHO.
Also, don't be afraid when laying down that front and rear bead on the block for the lower intake. Remember if you are using silicone to replace the gasket you need to make it thick so it squeezes out a little when you set the intake down. You want to set the intake down right away so it bonds to the intake and block, and be sure to clean the block and intake until they are shiny and then clean them with brake clean to make sure the silicone bonds.
Also 18-23 lbs. is all I have ever used. Not 25.
Good Luck.
the intake probably was not sitting down on the heads all the way when you were tightening,It may have looked like it but was just barely sitting up. I always use a rubber mallet to tap it down and make sure it is fully seated on the heads.
you also didn't put a thick enough bead of RTV on the ends. I made the same mistake when I assembled mine. Luckily, the engine was on a stand at the time and I was keeping an eye out for it while I tightened it down.
Curse said:
Looks like it sealed in the front. You might want to wipe/cut some of the silicone around where the distributor will sit, or setting down the distributor might be a problem. Good luck :nice:
:stupid:
Also you might want to readjust that first rocker. Looks a little off. J/K :rlaugh:
Yeah something could have been hindering the lower intake from wanting to go down (an obstruction).
A couple lower intake bolt partnumbers (though you already have them) are:
Lower Intake bolts – (hex) SUM-G1579HS
Lower intake bolts: arp-154-2001
Yep, trim a bit of that RTV around the distributor after it hardens...
