Why do downpipes gotta be so big?
Exhuast systems on a turbo kit can only have a little bit of back pressure. Back pressure in the exhuast(after turbo) can be bad. It can cause a turbo to spool slower. If the exhuast can't cross the turbo fast enough, it can't spin the turbo fast enough. If it backs up there, it backs up in the headers and crossover and over whelms the wastegate. You can over boost your motor, which can be very bad.
Also, you are trying to make a ton of power with one pipe, so it has to be bigger. Lots of guys run 3in into a splitter and 2.5 back like a normal N/A car.
Thanks guys. The reason I ask it that the pics I've seen look alot larger than 3". But now that I think about it those were probly close to 1000HP builds. what size DP do you guys use?
I run a 3. I've seen it said huys have made up to 1000hp with a single 3in. I'm gonna keep my 3in so I can tell customers what my kit can actually do. I'm gonn a be building a 800-1000 hp Maverick which will get probably only a 3.5.
Rich's is getting a 3in DP, and whether he wants to or not it's going to make over 500hp with 7 psi. He doesn't want that much, but can't go much lower on boost.
I run a 3. I've seen it said guys have made up to 1000hp with a single 3in. I'm gonna keep my 3in so I can tell customers what my kit can actually do. I'm gonn a be building a 800-1000 hp Maverick which will get probably only a 3.5.
Rich's is getting a 3in DP, and whether he wants to or not it's going to make over 500hp with 7 psi. He doesn't want that much, but can't go much lower on boost. He's whining something about not wanting a new block, or two used four cylinders.
