Why does my one of my GTs rev slower than the other one?
jpw3e
I have got two stock 95 mustang GTs. They have the same transmission and gears. My problem is that they dont act the same. One revs really fast and one seems to have poor throttle response when sitting in netural or driving. What does this sound like? How can I get better throttle response?
One quick check. The IAC has a bleed adjuster on the 5N95's, and it has worked its way lose on more than a few folks. When I played with the bleeder on my IAC (I was going to say "when I played with mine" but I knew that Michael would turn that into a sexual thing - as well he should. :D ). But you can loosen the screw enough to cause a hanging idle and some retarded funkyness before the idle begins to be affected, etc.
I still like pulling codes and doing a CBT and that's where I would start. Good luck.
