Why does my speedometer do this sometimes?
  • Thread starter Thread starter _jb_
  • Start date Start date Aug 7, 2005
_jb_
808
Michigan, Berrien County
Aug 7, 2005
  • Aug 7, 2005
Sometimes my speedometer will stay at 0 until I get into 4th or 5th gear, which is about 40-60 MPH. It happens maybe once every two weeks. It reads correctly, and I've changed the speedo cable last year since he speedo needle bounces around until I get up to about 30.
hllon4whls
BANNED
2,567
Covington
Aug 7, 2005
  • Aug 7, 2005
Lube the cable. Possibly will help. If the spedo is still bouncing, this will definatly help.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Aug 7, 2005
  • Aug 7, 2005
The bouncing is because there isn't enough load on the cable to keep it turning acurately. Prior to changing the cable, did your speedo act this way?
If yes, then look at the tranny drive gear. It could be stripped.
If no, look at the back of the insturment cluster, your speedo cable might not be plugged in all the way. (happend to me)
_jb_
808
Aug 7, 2005
  • Aug 7, 2005
It's lubbed.
_jb_
808
Aug 7, 2005
  • Aug 7, 2005
Yes the speedometer acted the same. It only bounces from about 5-30 MPH, the same for the 85 or 140 speedo.
And the cable is attached properly.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 7, 2005
  • Aug 7, 2005
mine bounces a bit in the lower speeds also. I guess its just getting old or something....
The Fox
354
Port Elizabeth
Aug 8, 2005
  • Aug 8, 2005
the stock speedo gear usually gets the "apple core effect" and get's stripped. And yeah lube da cable and make sure everything is good.
  • dan50
  • Jul 18, 2026
dan50
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
