Why don't the ports line up better from heads to intake?
pwcracer
347
Hastings, MN, USA
I set the intake gasket on the heads on my car and they line up well (Meaning the gasket intake opening is the same size of the gasket. when I placed the gasket on my stock intake, there is at least 1/4 inch gap all around, where the intake port on the manifold is much smaller than the intake port on the head. What is the point of this? I have been elliminating bottlenecks in my system, and now I think I ran into another one, I am installing GT40 heads, but I have to use my stock lower intake due to my Kenne Bell charger, only working with the stock intake.
My car is going to suck I bet
The lower intake on a 5.0 is a big bottleneck you need to port this if you want to make decent power unless you go aftermarket upper/lower intake... a good ported lower with the stock upper can be good for 300hp with tons of torque.
The lower should absolutely be ported for best power under a KB 1500. I've done a bunch and dyno tested a 80lb-ft increase peak and gains all the way from idle through the whole curve on one customers car who did before and after dynos with no other changes.
