Ive been seeing alot of people blocking off thier EGR. Why?? Does it add power? I need to know, cuz if its adding power, then Im doing it!! LOL
mr.b said:Stang8URMPRT, No unburnt fuel is recirculated back from the exhaust, I would hope you wouldn't be burning that rich!
VG30DE said:Positives:
1. I'm running stock 93 computer with NO EGR and I dont EVER get a check engine light, no added tuning is needed on a 93 down to disconnect the valve as long as you leave the sensor plugged in so the PCM still sees some kind of signal.
2. Stopping EGR flow greatly reduces the temp of the TB, upper plenum, and intake air charge temp, as well as preventing carbon deposits from building up inside the intake runners, which does happen over time.
3. Coolant is no longer needed to run through the EGR spacer since there are no hot gases going through anymore, and this also aids in cooling intake air charge. You can do a coolant bypass with no worries.
So yes, you DO indirectly get more power by stopping EGR flow and doing a coolant bypass simply because of the PCM adding more fuel and timing based on cooler intake charge and the engine recieving more dense air as a result of the colder temp.
Nagatives:
1. Slightly reduced fuel economy due to cooler intake charge.
2. Increased emissions output and may not pass emissions test depending on what state you're in.
You decide whether or not its a good idea.
This is not entirely true. Yes there is unburned fuel in the exhaust, but the EGR is not an attempt at reducing unburned HC. Your confusion here is very common. The EGRs only purpose is for NOx. It has very little effect on HC or CO. It works by reducing the amount of O2 in the intake charge. The exhaust gas serves as an inert gas which displaces atmospheric O2. With less O2 in the chambers there is less heat produced during combustion. Three things are needed to produce NOx. Nitrogen, Oxygen, and Heat. Reducing any one of the three will have a profound effect on NOx output.Stang8URMPRT said:If there was no fuel in your exhaust, there would be no reason for o2 sensors or air/fuel readings. There is always unburnt fuel in your exhaust unless you don't use fuel. lol
Well, if it was called that, it'd need an injector in the "GR" plate to function correctly.mr.b said:Stang8URMPRT, so why didn't they just call it the gr (gasoline recirculation) valve according to your logic? lol
Don't be mad you got told man. Just live with it and move on.
