94GTLaserRC said:I guess this is the set, huh?
http://www.sjdiscounttools.com/kas5344.html
bimmertech said:nope, the kit i have is made by gearwrench, comes in a big black case and has about 20pcs. picture a long handle that you put a wrench on and on the other end of the wrench you put your socket, adapter, whatever. it's great cuz when you put the wrench on the handle you can make it offset not just straight like that picture shows.
try this:
http://store.autotoolexpress.com/gearserbelto.html
the descrip doesn't say that it comes with a 3/8 drive bit you can put an extension onto but it does.
Striped5.0 said:![]()
Dont feel bad Rob Im not the best at working on my car either. Its a learning process.
Hey!!!!!!bimmertech said:nope, the kit i have is made by gearwrench, comes in a big black case and has about 20pcs. picture a long handle that you put a wrench on and on the other end of the wrench you put your socket, adapter, whatever. it's great cuz when you put the wrench on the handle you can make it offset not just straight like that picture shows.
try this:
94GTLaserRC said:Hey!!!!!!
My Mechanic brought this home for me to use tonight.
The kit is pretty neat, the way you connect everything together![]()
The only thing is you can pivot the head (neck area) at the point of entry of the wratchet into the idler pulley sq hole.
I just got home now, so Ill see how it works tomorrow.
RC
Uncle Log said:Not mechanical but....I once ordered new lugnuts for my car. How many did I order?....8, yes EIGHT!! How I came to that number I'll never know. Eight lugnuts wouldn't even cover 2 of the wheels.
