Personally I wouldnt go with such a large turbo, unless you have plans to do build a strong motor with an aftermarket block.. The T70 is rated at 840 horse, has larger wheels which equates to slower spool up time, and more rotational mass.
My point is.. with a turbo you don't want to go overkill, because you will increase spool up time, especially on a mild 302. SUre it's not a big deal to some, but when spool up time and drop off in power is important to you, you shoudl consider what Im saying. It's the same principal as some Honda boys throwing large T3/4's and such on there stock 1.6l and complaining about "LAG" ( I hate that word, lol)
My recomendation is.. 62-1 with a .68 housing. if you have the stock camshaft/springs/heads..
Or.. 62-1 with a .81 a/r housing if you have an aftermarket cam, or heads/intake. With the .68 on a basically stock motor you should see full boost around 2800rpm. with the .81 on a h/c/i motor you would probably see full boost around 3000-3200rpm.
