Why is my car soo slow?
OLDJUNK93
77
kansas
here's the deal. 2 years ago i went to the track and my car ran 15.10 all stock accept for catback, pulleys, k&n in stock box, and chip. now the chip is gone plus but i have added everything in the sig and tonite i ran 15.19 @ 91 mph. why is it so slow? i should be in the mid to low 14's now. any suggestions on what to check? any help would be greatly appreciated. thanks
You may need a new torque converter, as well as a shift kit, since the gears change things up a bit. I am the furthest thing away from an expert on this, but I always hear Gears/converter/shift kit in the same sentence.
Could you also be spinning the tires and losing time there?
are you power breaking off the line or just pushing the gas when the light turns green, and are you shifting it or are you letting it shift automatic? Also what rpm is it shifting at?
Converter is the problem, the stock stall is way too low for any good times to be run at the track.
Check out my sig for my times and notice that I'm in the 13.8's with not much more than you have. The stall and some ET Streets brought my times down to the 14.1's with 3.55's in the car. 13.8's with the 3.90's.
He shouldn't need a torque converter. He's down on power for some reason.
With about the same mods, i was running 14.4's @ 97-98MPH all with stock converter and no shift kit in the AOD.
