Well last year we replaced a older stock clutch with a new NAPA clutch and it helped lighten the firmness a bit...and my car has also got a UPR adjustable quadrant and my clutch pedal is considerably harder to push in than my friends 90 gt with a Centerforce DF? Is it my clutch cable?...clutch pedal assembly?...and you can hear a creaking when you push in the cluth (the further it goes...the noise picks up slightly)...is that the cable stretching?
Any suggestions would be great...
get one from MM, or diversified for around $40.
...and when I push in the clutch it isn't a smooth push or release...for example...when you release it it almost catches in certain spots...very light but noticeable...I'll have to check that firewall hole...will I be able to see it by the clutch pedal assembly...tight fit I know...but I'm sure me and a flashlight can squeeze under there...my cable does have a awkard looking bend in it...it curves on top of the k-member...isn't it supposed to go through something or underneath it?
)...or do I need a "special" cable for the UPR adjustable firewall quadrant (installed by previous owner)...?
...the only problem is the clutch cable holder in the engine bay only goes on one way because of two little holes (one for the bolt and the other for alignment) and it looks awkward...do you got a pic of how yours is routed...so it goes under the k-member...?
