Why no spark???
jay90GT302
My dad's 68 GT 302 wont start up cuz he's not getting any spark. He's getting power to the ignition coil, but then when we do the ground test we're not getting any spark from the wire going to the distributor when cranking. Is it just that the coil is shot or could it be something else??? Thanks
if you still have points, check to make sure the gap hasnt closed uo. also check them becauwse sometimes you get metal transferring from one side to the other and they contact preventing a spark. one more thing to check is to see if you get power through the coil. do this by disconnecting the ground wire, and hook up your voltmeter between the coil negative, and a ground. if you get no voltage reading, then you have a bad coil.
