my car for about two months has been running high on the oil pressure guage... i don't know if its broke or whats wrong..... sence i have the stock guage it reads to the TOP just below the "H" line... after it warms up its ok seems to run in the middle and lil higher... what causes high oil pressure? anything i should change check??? any info thanks
on a lot of newer fords will show normal oil pressure no matter what the pressure is. i have a 67 mustang that did the same thing... it was real high when the motor was cold and normal once it warmed up. never had a problem out of it. when i put a new motor in it, it has normal oil pressure all the time. i never figured out why it did that. but i dont think you will have a problem unless it stays high all the time. then you should watch out for bearing errosion.
