This is in my 94 mazda mx6. 2.5fi manual 5 speed with overdrive and regular distributor.
As far as I can tell, if I run an entire tank of gas out and check the milage I will get about 1.5mpg less than if I fill up every time I get to a half a tank. Usually mpg is about 23 if I measure it from a full tank. I get 24-25 if I keep the tank from dropping below a half a tank. This makes no sense, because you would think that the extra weight of the gas would make the milage worse.....been testing this for several months now.....
...I would be more worried about monsoon water entering the tank! And you would think that if there was a reduction in fuel pressure I would actually be running lean and have better gas milage and misfires. Runs just fine (when its not breaking down that is)
