Umby
Hope this helps...
As mentioned before, the flashing of light represents different does... one flash, pause, two flashes = code 12
This chart is for 92-93 cars.
The chart for 90-91 cars and other useful info can be found at http://www.veryuseful.com/mustang/tech/airBag/
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE
| Code | Description | Pinpoint Test |
| No Indicator | Inoperative air bag indicator circuit | A |
| Continuous Indicator | Diagnostic monitor disconnected or inoperative | B |
| 12 | Loss of battery power to air bag firing circuit | C |
| 13 | Front crash sensor or air bag circuit shorted to ground | D |
| 21 | LH B-Pillar safing sensor not mounted to vehicle properly | E |
| 22 | Safing sensor shorted or stuck closed | F |
| 23 | Open connection in safing sensor feed circuit | G |
| 24 | Safing sensor diagnostic circuit open | H |
| 31 | All system air bag(s) open | I |
| 32 | High resistance or open circuit in driver air bag circuit | J |
| 33 | High resistance or open circuit in passenger air bag circuit | K |
| 34 | Low resistance in driver air bag circuit | L |
| 41 | Open connection in forward crash sensor circuit | M |
| 44 | RH front crash sensor not mounted to vehicle properly | N |
| 45 | Center front sensor not mounted to vehicle properly | O |
| 46 | LH front crash sensor not mounted to vehicle properly | P |
| 51 | Diagnostic monitor internal thermal fuse open | Q |
| 52 | Backup power supply fault | R |
| 53 | Diagnostic monitor internal fault | S |
| 99(1) | All crash sensors disconnected | T |
(1) - Air bag indicator flashing very fast continuously.
