Why would this happen?
  • Thread starter Thread starter suki243
  • Start date Start date Jul 6, 2007
suki243
662
Southern California
Jul 6, 2007
  • Jul 6, 2007
Hey guys, I recently pulled out the carpet and insulation and there was rust, but only on the passenger side. The drivers side was in nice shape.
The cowl doesn't leak, its sealed. But... I do remember that when I got the car the heater core was busted. It was pretty bad and I could tell that they were original heater hoses so I doubt he ever replaced the heater core. When my parents bought the car all the owner said was that the heater didn't work well. So...who knows how long the heater core was leaking...
Would that be a contributor to the rusting? another cause might be is the fact that the seat bolts don't have plugs and grommets underneath.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 6, 2007
  • Jul 6, 2007
I think you answered your own question: heater core leaking.
Another possible leak could be at the windshield; a leak will run to mysterious places and then the floorboard.
Blu-Steel
92
Waynesville, MO
Jul 6, 2007
  • Jul 6, 2007
The heater core was most likely the culprit, or at least a major contributor. Heater cores go bad a lot because people don't flush their cooling system enough. It looks like yours did just that. They tend to leak slowly at first so most people don't really notice it or they just ignore it and will "fix it later". Touble is the rust starts fast. I've had several 66 Mustangs and they all had the usual leaks; winshield, heater core, cowl vent, but one had a leak that took me a year to figure out. I took everything apart, put cowl vent caps and resealed the winshield several times but still it leaked. Turns out a hole had rusted through the firewall in the fenderwell and water would seep in through it.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jul 6, 2007
  • Jul 6, 2007
I read the 1st sentence of your post and the 1st thing that came to mind was "heater core".
Capt Dan
237
College Station, Texas
Jul 6, 2007
  • Jul 6, 2007
do you also have a/c?
Condensate drain could be leaking on that side too.
The carpet and pad will stay wet and cause rust.
suki243
662
Southern California
Jul 6, 2007
  • Jul 6, 2007
I don't have an A/c, I replaced the heater core but i didn't replace the hoses last time, I will this time. I pulled it out to put in new sound dampening plus the painter didn't cover the cowl while sanding and now the vents are full of dust and what not. So i'm gonna clean the heater box out .
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
M
  • mnky99
  • Sep 5, 2025
mnky99
M
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
D
Paint and Body Passenger side leak on carpet
  • dqureshi06
  • May 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
limp
