Since the wastegates are technically off, I got to thinking about that. Since I'm hobbled w/ a stock HG,and therefore limited to 10lbs or so max boost, why wouldn't I just remove the 5lb springs, and replace them with the 10 pounders? Rather than go through a (what looks like a complex process) of setting up the MS to regulate the boost via the boost control solenoid, doesn't it make sense to just "set it and forget it" by installing the appropriate spring?
