wierd noise from exhaust hose
diponyou50
138
11
it sounds like a coffee maker coming from i think wut is the passenger side near the rear of the head kinda sounds like it is comming from the exhause hose.i really have no clue.if there is anybody who could help please do so.thanks alot
Usually that sound is a loose smog pump connection. Do you still have the smog pump? There are multiple hose clamps on all the hoses runing from the smog pump to the blow down tube that goes to the mid pipe (in your case your off road h pipe. It does not need to be used, as it blows on the cats, and since you have none, there is no need) The offroad h pipe I had on my car when I bought it didn't come with that connector to hook the tube back up, so the previous owner put a bolt in that hose on the bottom off the valve and clamped it in. Anyway.. just check all those clamps to see if any are leaking.
