  • 1994 - 1995 Specific Tech
Wierd problem WOT
  • Thread starter Thread starter Sivstang
  • Start date Start date May 9, 2006
Sivstang
212
  • May 9, 2006
I changed my wires, cap + rotors, oil change, seafoam in intake + 1 can for the fuel tank, and changed my fuel filter. My problem mostly resides in the first start up, I will try to rev it up and it almost bogs out. I will sputtered, if I leave it alone to idle it high revs for about 30 secs and slowly drops down.
When I do a WOT in 1ST gear, well any gear really. It will sputter and just doesn't seem any power will be made, but the rpms will climb, just doesn't seem to go anywhere if that makes sense.
And ideas?
Thanks
Travis
A
Ar_sn95
28
  • May 9, 2006
is your maf clean
Sivstang
212
  • May 9, 2006
I'm a little afaid to attempt to clean it trufthly. I don't want to mess up the wires.
A
Ar_sn95
28
  • May 9, 2006
just use alcohol and a q tip, if there is a bunch of black stuff on the two wires then yo know it is dirty, when I cleaned my maf it felt like I got 50 or more hp at least. A very big diff.
bill302
2,131
alabama,gadsden
May 9, 2006
  • May 9, 2006
here you go click on link and perform steps part 1-5 under solving idle problems...
http://www.muscularmustangs.com/maintain.php
HISSIN50
34
129
May 9, 2006
  • May 9, 2006
Also make sure you dont have any vac leaks.
Good luck.
Sivstang
212
  • May 10, 2006
I have done all the steps BUT MAF clean. I will give it a shot later this week I suppose... I will also be changing plugs and checking the WOT voltage seeing if it's within range. oh and check for vac leaks. Thanks for the tips!
4Jenna
4,326
AZ
May 10, 2006
  • May 10, 2006
I had a similar prob where the car would die at 4k..was my fuel pump
Look for vacc leaks as said....any popping noise thru the intake?
HISSIN50
34
129
May 10, 2006
  • May 10, 2006
Chris, werent you also having an issue with light load and/or low RPM surging or something too? Was it two separate issues?
Glad to hear the FP took care of it.
Sivstang
212
#10
  • May 10, 2006
  • #10
Yes actually there is, it only happens when I do a WOT rev at FIRSt start up from sitting all night or for about 4 hours or so. It will og on the WOT rev and pop. Kinda strange.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
2.3l mustang hard starts and bogs and stalls when you floor it from idle
  • declan
  • Feb 19, 2025
  • 2.3L (N/A & Turbo) Tech
2K
2.3L (N/A & Turbo) Tech Feb 28, 2025
declan
D
