  • 1994 - 1995 Specific Tech
Wierd Steering Column ignition problem
  • Thread starter Thread starter WhiteDevil
  • Start date Start date Oct 28, 2004
WhiteDevil
2,717
San Diego
Oct 28, 2004
  • Oct 28, 2004
Hey i was wondering if anyone else has had a problem with their turn key ignition. It just started recently, BUt my key hole has a ton of play back and forth in the steering column. Yesterday, i put the key in and it wouldnt turn. I had to play around with it for 15min just get the key to click in just right so it would turn. Its kinda getting worse, anyone else have a problem like this?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Oct 28, 2004
  • Oct 28, 2004
Sounds like you need a new ignition lock cylinder. It's pretty easy to pop it out and replace. Only problem is you'll have to bring the new one to a locksmith and have them cut the cylinder to fit your current key.
New ignition lock cylinders are like $20-$30 online. Good luck!
WhiteDevil
2,717
San Diego
Oct 28, 2004
  • Oct 28, 2004
Cool, anyone else have any ideas on whats goin on? Or know where i can get one of these??
zenboy99
2,212
Madison, WI
Oct 28, 2004
  • Oct 28, 2004
This was a common problem with our cars, there is a TSB on it. My car has been doing the same thing, I can actually take the key out of the ignition while the car is running.
M
madams74
664
Maryville, TN
Oct 28, 2004
  • Oct 28, 2004
I always smack the key in because the square part at the top is hitting on the edge of the metal that you grab. Look real close and see if it is not even going in all the way.
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Oct 28, 2004
  • Oct 28, 2004
You too? I figured it's just the way my key is cut - its notches are pretty shallow. Whenever I get a new key cut, it stays in the ignition. But after it wears a while, the key can be removed.
It don't hurt anything, so I haven't bothered with it.
scarless
175
  • Oct 29, 2004
I got mine at the dealer for $40 and they cut the door bumps for free with two keys. Locksmiths wanted $120 to do it. FYI, the auto parts keys won't open the doors or trunk so you will have to use your old key for them and new key for the ignition. The dealer key opens everything but the glove box. I think a locksmith will key the glove box for about $20. A full lock set for doors, trunk, glove box, ignition is like $130 at the dealer. If you want, I have one of those auto parts ignition sets I'll sell you for $10, it cost me $19 and they won't take it back.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
75 mustang column/ignition switch wiring diagram
  • DFlikks
  • Aug 7, 2025
1974 - 1978 Mustang II Talk & Tech Aug 7, 2025
DFlikks
D
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
