krang00 Founding Member Oct 29, 2002 79 1 0 Allentown, PA Feb 20, 2006 #1 Feb 20, 2006 #1 Will the stock grey bullet rims from a 2006 fit other years?
K Kerrdogg New Member Apr 27, 2005 30 0 0 Feb 21, 2006 #2 Feb 21, 2006 #2 Two of mine are on the back of a 91 coupe that was converted to 5 lug, they fit ok, just make the rear sit up higher due to the tire height difference.
krang00 Founding Member Oct 29, 2002 79 1 0 Allentown, PA Feb 21, 2006 #3 Feb 21, 2006 #3 When you did the 5 lug conversion, I assuming you used SN-95 spindles? If that's the case then they should fit any 94-03 mustang as well, correct?
