  • 2005 - 2009 Specific Tech
will 4.10's rev to fast in a auto?
  • Thread starter Thread starter dbrufus1234
  • Start date Start date Jun 11, 2007
  • 3
First Prev 2 of 3 Next Last
xtweakerx
411
Jupiter,FL
Jun 14, 2007
#21
  • Jun 14, 2007
  • #21
what do u guys recommand for me the 4.30's then?
all i really plan to do in the future besides gears is intake and tune, possb UD pullies. but not much really just want a simple setup that works for high 12's low 13's on sticky rubber.
I'm currently running M&H Drag Radials but they are about 1 inch taller than stock so right now w/ my 3:55 gears they are really like 3:30's or something and im running just about the same time at the track as if i was running street tires.
With that said i want a bigger gear. Will 4:30's work for me in the long run on the street w/ street tires and at the track w/ my radials or go for 4:10's?
Also any idea of how this will change my shift points at the track in a manual w/ 4.30's.. if i was shifting w/ 3:55's around 5800-5900 rpms, how much higher will it be w/ the new gears? I was going through the traps in 3rd gear around 6000 rpms around 100mph w/ 3:55's..
alright as always thanks guys
Five Oh Brian
552
Pacific Northwest
Jun 15, 2007
#22
  • Jun 15, 2007
  • #22
....Will 4:30's work for me in the long run on the street w/ street tires and at the track w/ my radials or go for 4:10's?
Also any idea of how this will change my shift points at the track in a manual w/ 4.30's.. if i was shifting w/ 3:55's around 5800-5900 rpms, how much higher will it be w/ the new gears? I was going through the traps in 3rd gear around 6000 rpms around 100mph w/ 3:55's...
With your manual trans, you have more overdrive than us automatic guys (.68 vs .71), so go with the 4.30's. You don't need to change your shift rpm's. However, you may want to shift in the 6,200 to 6,500 range to get into peak torque in the next gear. You can easily move the redline up with a handheld tuner (SCT, Diablo, etc.). I used my Diablo tuner to change my redline to 6,800 rpm's and it shifts great in the 6,200 to 6,500 rpm range (there's still power past the factory 6,000 rpm redline, but not past 6,500 rpm's). With 4.30's you'll be using 4th gear to get through the traps.
BlackGT4.6
103
In.
Jun 15, 2007
#23
  • Jun 15, 2007
  • #23
4.10s n.a 3.73s fi
C
claytucc3
825
Santa Clarita, Ca
Jun 16, 2007
#24
  • Jun 16, 2007
  • #24
Hey bro...let me know how your gears feel after you install them....I need to get a set myself and I am researching the mileage to performace on the lower gears.....clay
xtweakerx
411
Jupiter,FL
Jun 16, 2007
#25
  • Jun 16, 2007
  • #25
cool ill talk to ford dealer when i go get my oil change because i was going to have them do the install, wouldn't they change the computer though part of the gear install to change the rpm's?
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Jun 16, 2007
#26
  • Jun 16, 2007
  • #26
The SCT tuner did that as well. I know the first time I carried it past 6000 I was like
Five Oh Brian
552
Pacific Northwest
Jun 16, 2007
#27
  • Jun 16, 2007
  • #27
I work at a Ford dealership. We have a great service department with excellent mechanics who've been there forever. They installed my 4.30's in my 03 Mach 1 and the 4.10's in my T-Bird, and the 4.10's in my 07 Mustang GT. Unfortunately, they can only adjust the speedo calibration a small fraction of what you need after a gear swap. This means you have to buy a tuner to do it yourself, or have an aftermarket shop burn you a new tune.
Five Oh Brian
552
Pacific Northwest
Jun 16, 2007
#28
  • Jun 16, 2007
  • #28
I originally set my GT's redline to 7,000 rpm's and thought it was awesome on the street (manually shifting my automatic), but the quickest times at the track seem to have been shifting manually at 6,200 to 6,500 rpm's. Not sure about the SCT Tuner, but the Diablo only allows shifts up to 6,200 rpm's in drive (or up to 7,000 rpm's if you shift manually), so I'm guessing that they feel 6,200 rpm's is optimum for performance.
But, yes, there is definitely some power still available past 6,000 rpm's in these 4.6L 3V's.
Just ordered a 3,500 rpm stall converter for my GT last night. Can't wait to get that installed to make this automatic really launch violently at the strip. Also, each shift will be even better as the converter will keep the revs at 3,500 plus instead of dropping way down between shifts to way below peak torque (like a manual trans or stock automatic). If I can keep my car in the 3,500 to 6,500 rpm range for the entire 1/4 mile, I suspect there is a 12.90 timeslip to be had (on drag radials, at least).
kooldawg6
Aug 31, 2006
1,679
Central VA
Jun 18, 2007
#29
  • Jun 18, 2007
  • #29
I'll be interested in your results and comments on the new stall converter I've read where that alone can drop 1/4 mile ET by 3-4 tenths. I'm curious to how long the tranny will last setup like that however.
xtweakerx
411
Jupiter,FL
Jun 18, 2007
#30
  • Jun 18, 2007
  • #30
why cant ford change the tune/computer portion?
I know they have that one upgrade package.
Tune,intake,gears.
so obviously their has to be some kind of tune for the gears.
im going to speak with them about this stuff.
However i would like my gears installed by them but damn then next ill have to buy a tuner from like brenspeed and tell them to make me a custom tune w/ 4.30 gears plus w/e.. $$$$$
Wish i was rich like most of the people on here putting posts up like
"hey i have 6,000 dollars what should i do?" i have to take baby steps and do 1 mod at a time.
Five Oh Brian
552
Pacific Northwest
Jun 18, 2007
#31
  • Jun 18, 2007
  • #31
The worst enemy of a tranny is heat. A high-stall speed means a lot of slip, which creates heat. I ordered a lock-up converter, however, so at cruising speeds it will engage a clutch in the converter to lock it up so it isn't slipping (or creating extra heat). During normal driving, it won't be stalling (slipping) to such a high rpm, so it should be fine long-term.
Every manufacturer I talked to said their stall converters were good for 5-7 tenths in the 1/4 mile. That's a bit optimistic, I'm sure, but I'm running 13.40's with the stock converter on the stock tires, so I'd be happy getting into the low 13's (13.0's would be nice). I'm really on a mission to get to 12.90's, though, without any of the normal bolt ons (CAI, axle-back, etc.). I'm working on raising the efficiency of the driveline to keep the car looking/sounding stock inside and out.
Five Oh Brian
552
Pacific Northwest
Jun 18, 2007
#32
  • Jun 18, 2007
  • #32
Tune,intake,gears.
Ford has a tune for the 3.73 gears in their Ford Drag Pack. The factory computer can't be tuned at the dealership level for gears beyond that, according to our techs. There is just enough give in the factory computer to adjust for different height tires, but not big gear changes.
You do NOT have to be rich, and I certainly am not rich. I bought my DiabloSport Predator Tuner for $369 online at www.rpmoutlet.com. It was already pre-programmed with several tunes, plus you can customize lots of things yourself for free after that (i.e. gear ratios, tire sizes, speed & rpm limiters, shift points, etc.). I bought the 4.10 gears for $220, and paid $250 in labor for the install, so the gears, install, and tuner set me back $840 total. Not a bunch of money for 30hp, several tenths, and several mph improvement in the 1/4 mile. I did the gears and tuner in October right after I bought this GT brand new. Didn't have a first payment for 45 days, so I had some money to spend with no car payment the first few weeks I owned it. Here it is 8 months later, and I just ordered my next mod ($470 for a 3,500 rpm stall converter after shopping around a lot). I'm figuring about $200 labor to install it. Shouldn't require any tuning, but if it does, I already own the tuner (and it came with a free custom tune offer for later should I need one).
xtweakerx, if I were rich, I would have bought the Shelby GT500 instead of the basic Mustang GT.
StonePony
218
#33
  • Jun 18, 2007
  • #33
The stall speed converter won't affect your 2nd through 5th shifts at all. The lock-up clutch will be engaged after 40 MPH or so.
If you can get a stall converter installed for 200 you are magic.
That install requires transmission removal and re-installation... all for $200 is a bargain. I paid 800 to have my transmission removed and replaced.
kooldawg6
Aug 31, 2006
1,679
Central VA
Jun 18, 2007
#34
  • Jun 18, 2007
  • #34
Modular Mustang Racing has a windage tray(<$130)that claims up to 15 HP for stock engine and even more for on modified engines. Wonder if that would be worth it. Freeing up that much HP would be sweet! Also, have you swapped out your driveshaft yet? I've heard that is good for another several tenths reduction being that you can lose upwards of 30 lbs in rotational mass!
Five Oh Brian
552
Pacific Northwest
Jun 19, 2007
#35
  • Jun 19, 2007
  • #35
Good info on the shifts and lock-up - thanks!
I work at a Ford dealership, so I pay a lot less for labor rates than a normal customer would. I've been told 3-4 hours labor for trans R&R, so that should be about $200 for me roughly.
Five Oh Brian
552
Pacific Northwest
Jun 19, 2007
#36
  • Jun 19, 2007
  • #36
The one-piece driveshaft is next on my list, but they're expensive, so it may be a couple months before I can talk my wife into more mod money. We have to strike a good balance between modding the Mustang and the house - lol. The windage tray would be great if it keeps the crank from sloshing through the oil so much. I can't imagine freeing up 15hp by that alone, but it still sounds like a worthwhile item to install.
While some people throw lots of money at bolt-on's to get a couple horsepower here and a couple horsepower there, it's interesting how much horsepower we already have that can be free'd up by increasing the driveline efficiency to get more of that horsepower to the ground!
kooldawg6
Aug 31, 2006
1,679
Central VA
Jun 19, 2007
#37
  • Jun 19, 2007
  • #37
TRUE!!!!! UDPs, windage tray, driveshaft and delete plates...I don't see why we couldnt get back close to 10%.
When you do add additional HP, you will see a slightly higher gain from that as you aren't losing as much since you've made your car more power efficient.
H
Hoboattacker
542
Baton Rouge (LSU) / Houston, TX
Jun 20, 2007
#38
  • Jun 20, 2007
  • #38
The 05+ valvetrain isn't good enough to go past 6200-6500rpm's stock. That's why they best times are shifting at about 6200. You are right at the end of the powerband and when you shift it puts you right back at the beginning of it.
xtweakerx
411
Jupiter,FL
Jun 21, 2007
#39
  • Jun 21, 2007
  • #39
Where are u guys getting your gears installed?
Local speed shops?
The dealer?
Steeda?
kooldawg6
Aug 31, 2006
1,679
Central VA
Jun 21, 2007
#40
  • Jun 21, 2007
  • #40
Local speed shops?
The dealer?
Steeda?
I went to a speed shop who's specialty is Mustangs/Lightnings and are a sponsor of the Mustang Club of which I'm a member.
  • 3
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
