I am going to convert my `66 6cyl over to a 302 and 5-lug.I can get a `67 rearend drum-drum pretty cheap,but will t fit the `66 easily? I heard that it might be a lil wider,but would that be wider overall,or are the spring perches wider also?
65fsbkhipo said:Beg to differ...Happy New Year!
D.Hearne said:The 65-66 spring perches are the same distance apart as the 67-70 Stangs. I pulled a 57-59 Ford 9" rear out from under a 66 Stang and bolted it right under a 67 Stang, no problem. 12sec67 was correct. All the early Stangs , Fairlanes, Torino's, Comets, Mavericks, and other mid size cars shared the same spring perch spacing.
I know the 67-70 9-inch is a larger tube than the 65-66 9-inch, it did not have the dramatic taper the early ones did. But are you sure that is also true of the 8-inch?bifs66 said:I installed an unmodified 9" rear out of a 68 Cobra Jet Mustang into my 66 Fastback. The spring perches are a perfect fit. However, all 67->up 8" and 9" rears have a slightly larger tube dia at the spring perches than the 65/66 Mustangs.
).allcarfan said:I have a friend with an unmodified 9" from a 69 mach one in his 65 coupe. Fit perfect. He is selling it to me...yay.
