will a 10.5 inch slick fit on 10 holes and on an 89
dastang2
2,020
tx
will a 10.5 slick fit on a 10 hole wheel and with that fit under an 89. it is 28 inches tall. is that too much does anybody know if this will fit or not.
With enough fender rolling and inner fender hammering, also with the quad shocks and tail pipe gone, it will, but you'll still get rubbing with a 28 inch tall tire, but it'll probably be ok at the track. That tire would be better on a Weld with the right amount of back spacing. Also you're running a pretty wide tire on a 7 inch rim, which you could prevent if you had 8 or 9 inch Welds to use.
As long as they are et streets and not et drags they will work. THe et drag 10.5's are almost 12 inches wide. You won't have to do anything with your tailpipe or the quad shock if its still there, the only problem is the height and you still might get away with it as long as you don't have GT ground effects.
