will a 190 fuel pump be OK on a superchaged car?
Hey I got a 306 with a s trim ..the whole nine yards with a t rex fuel pump and a stock in the tank pump..My car is starving for fuel..I was recommended by the professionals to get a Walbro 255 pump and thats what I am gonna do..I also use 42 LB injectors
yep.... def bigger fuel pump plus the 24 lb injectors are def not enough, you'll def gonna max them....
Cant really overpump a injected 302, go with the biggest pump (255 hi pressure) and be done with it. When the boost level goes up so will the hp, the fuel line size, rail size , and pump size should correspond.
mike.
