will a 89-93 mass air meter work in a 95
90lxboost'n
55
Ohio
I have a 95 GT I am just wondeing if a mass air meter from 87-93 will work in our stangs. I am wanting to make a pipe to get rid of the bend in the rubber pipe from mass to throttle body. I am wanting a mass that will just plug and play. Will a mass from a lightning and the 42 lb. injectors go right in and work or do you have to do some splicing..
tjh566
608
Northern Va
To use the lightning you have to tune the computer via Tweecer, etc. or have a shop tune it and burn ya a chip or something along those lines, it isnt based off injector size, its based off of CFM/Voltage, the computer controls the fuel
HISSIN50
33
129
The SN95 MAF is larger, making it an attractive upgrade for foxes (IIRC, the 94-95 MAFs [not MAS's!] are the same size as the 93 cobra MAF.
A fox (non cobra) MAF is kinda restrictive but it will work if the mechanical bolting of it in is achieved. You can get an adapter for making a 94-95 MAF bolt up to a fox, or cut the flange off.
Good luck.
