Will FMS 19 lb High flow injectors work with stock MAF?
1993SSP
1,194
Ky
will the FMS high flow 19lb injectors work ok with the stock MAF? Im doing an engine swap and need to know if i can use these or do i need to stick with the stockers? thanks
how much more do the high flow injectors flow than a stock injector? if it is close, i would not sweat it - the puter can trim it down.
good luck.
The term "High Flow Injectors" is marketing hype to get you to think you're getting something more for your money...
Marketing is where all good technical people go to become corrupted... :D
i was thinking the same thing (why i originally asked for specs) - if it was 'high flow' enough to make a difference, would it not be a numerically higher lb/hr injector (i.e. a 20# injector)......... :)
