Hello all, I recently purchased an 01 automatic GT and I like it so far. But it definitely needs more power.
I recently changed the valve cover gaskets, and I figured since I don't have anything better to do at the moment, I'd change the cam shafts as well. I'm looking at stage 3 XE270AH cams from Comp Cam. I'm of course going full bolt on as well. I have the stock 4 speed auto, and they reccomend a 2000rpm stall. Is there danger in running these cams with the stock trans? Or should I go ahead and install, upgrading the trans later?
I'm expecting to make 330Hp+
