will I need to change my pushrod length
94blackgt 1621
79
im going to change my stock head setup and steeda#19 cam, to the anderson ford motorsport N-41 cam with pro-magnum roller rockers and TW heads. will i need to change my pushrod length?
yes.... i recomend getting an adustable length pushrod to check exactly the length you need. They are less than $15 bucks, and cheap insurance...if your pushrod length is off by just .20 it will lead to premuture valve guide wear and oil consumption problems.....no two engines are the same...use the checker
I also rec this...also e-mail tfs they can give a basepoint to start they told me what length i measured and sure enough they were dead on tfs rocks
