Will performer RPM heads fit on an otherwise stock 302
Andres2882
316
Will they? Friend says that with the stock cam I shouldn't have a problem while my other friend said I'd have to notch the pistons. Anyone have any first-hand experience?
I thought the Eddy's were some of the only heads to have 2.02" intake valves to work with stock pistons? I guess if you run a bigger cam then you can run into problems. My TFS heads have 2.02" intake valves, I'm running the stage 1 cam with .499" lift on intake, and have no problems. Might wanna check the valve angle and compare the two before assuming they will work.
Trick Flow are the only ones that I'm aware of that you can run the stock pistons with 2.02 valves.
