Will removing carbon trap cause me to fail emission test?
BadAndy72
17
I'm going to be moving to San Diego in about 3 months but I really want to do a few performance mod's before I go. I assume that if I install a JLT CAI that the carbon trap will be removed by default since it's located in the stock air inlet. Does anyone know if the removal of the carbon trap will cause me to fail the e-test down there? I also plan on doing a cat-back system so I should be OK there if I keep the stock cat's.
Any thoughts are appreciated....
Whether a supercharger is CA street legal depends on the SC. The only one I know that is CARB certified is the one from Saleen. Any of them that require a non CARB-certified CAI will cause you to fail.
BadAndy72 - once you move here and pass the emissions test, you should fall into the normal schedule (you can confirm with the DMV, I'm just a guy that lives here). No test required for vehicles 6 model years old and newer unless you transfer ownership, in which case testing is not required if the car is 4 model years old or newer. New-ish vehicles registered in another state that move here are not exempt from the initial test when you first bring it here.
Once the car is 7 model years old, it needs to be tested every other year, except for some areas out in the sticks, but SD will not be one of those places, unless you have a wicked commute from waaaay out.
All the info you need can be found at the California DMV site: http://www.dmv.ca.gov/
