Will stock motor benifit 1.7 rollers?
  • Thread starter Thread starter pitstang420
  • Start date Start date Feb 19, 2009
pitstang420
22
Bethel, Ohio
Feb 19, 2009
  • Feb 19, 2009
I was wondering if a stock motor and intake with just cold air intake and nitrous benifit 1.7 roller rockers I have them allready from another project they where going to go but didn't THANKS for any input and would it give it any diffrent of a idle?
dcurtis
688
Feb 20, 2009
  • Feb 20, 2009
If they are free, then yes there is a benifit, less friction, due to the rollers, but I would not buy them to put on a other wise stock engine. the heads are the weak link on 5.0's, start there then worry about the cam, or 1.7's.
pitstang420
22
Bethel, Ohio
Feb 20, 2009
  • Feb 20, 2009
Thanks any one else have any thoughts??
89hatchlx
58
Dirty South Jerzzzz
Feb 20, 2009
  • Feb 20, 2009
I have read in a few mags that putting 1.7's on stock heads with weak springs can be a pretty bad combo. I would just save them for when you get a set of heads. Even a set of gt40 heads with 1.7's is the same setup ran on the cobra's. Good luck
V8_Kind_Of_Guy
73
Denver, Co
Feb 20, 2009
  • Feb 20, 2009
I have GT40P heads with the 1.7's and new springs and runs good. But I also read that weak springs with 1.7 will hurt power. I might have read that same article. I believe they put it on a 100k motor that was almost all stock and it lost like 10 hp I think.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Feb 20, 2009
  • Feb 20, 2009
1.7's will usually hurt an otherwise stock 5.0 (HP wise) due to the valve float RPM being lessened. Stock 5.0 springs and heads are the weak link and don't really flow that well.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Feb 20, 2009
  • Feb 20, 2009
If you replace the springs, however, then the 1.7s will be worth a small gain. Probably not a large enough gain to warrant the cost of replacing the springs and time/trouble, but a gain nonetheless.
parrish5o
Dirty South
Feb 20, 2009
  • Feb 20, 2009
I would just hang on to them until you get a few better parts. Once you replace the heads or at least the springs go ahead and install them then.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
