  • SN95 4.6L Mustang Tech
Will Synthetic Tranny fluid make a diff??
  • Thread starter Thread starter 2003BlackStang
  • Start date Start date May 5, 2004
2003BlackStang
188
  • May 5, 2004
Will synthetic transmission fluid make a big difference and what kind should i use?
LouisianaZJ
237
May 5, 2004
  • May 5, 2004
this is what someone told me, not sure how it actually works in the tranny
"One thing you need to know is that Red Line D4 ATF (Mercon V) is not good for your T-3650 tranny. The synchro rings are carbon fiber, and RL makes these rings brittle. I know it's wierd, but a lot of teh Mustang folks on www.mustangworld.com are using GM Synchromesh manual transmission fluid in their T-3650 trannys. GM Synchromesh takes the characteristic 1-2 shift grind out of the picture completely. Don't use Red Line in the T-3650 tranny."
wms004
2,864
Los Angeles
May 5, 2004
  • May 5, 2004
I've had the RL D4 ATF in there for over 5,000 miles. Can anyone back up the statement above? How much and where to get GM Syncromesh?
Graham052
193
  • May 5, 2004
Ive had redline in mine now for awhile too, and would like to know more info. Is it the same for my transmission in my 96?
Turbo92PGT
746
Auburn Washington
May 5, 2004
  • May 5, 2004
I've had redline in my T45 for a while now. Its not that great =/ I liked using maxlife and lucas oil stabilizer better.
Your 96 has the T45 transmission
G
Ghost001
398
California
May 5, 2004
  • May 5, 2004
I think it's a good idea for an auto tranny. I put Amsoil synthetci ATF in my Stang about a year ago, when it had 15,000 miles on it. It now has 36,000 miles on it, and I've never had a single problem.
Amsoil is good, because it does not break down as easily at high temperatures.
I just changed the tranny fluid again a couple of weeks ago, and the old Amsoil fluid looked pretty good, still red, and not brown.
I'd guess I'd stay away from Redline, if what that person above said is true.
2003BlackStang
188
  • May 7, 2004
Anyone got more info on GM synchromesh? Or what they use my car is an 03 5 speed?
2003BlackStang
188
  • May 7, 2004
Another thread stated that ford puts MOBIL 1 synthetic in stock is this stuff just crap or is that guy wrong? What should I use and how much any info to help me will be appreciated. Ford is hooking me up with a new tranny and i want to change the fluid first thing so the prob wont happen with this tranny. Thanks for your advice in advance anything will be nice.
2003BlackStang
188
  • May 7, 2004
ANYONE???????????????
wms004
2,864
Los Angeles
May 7, 2004
#10
  • May 7, 2004
  • #10
I am that guy. Look at your manual.. it says in the back, Mobile 1 ATF
2003BlackStang
188
#11
  • May 10, 2004
  • #11
Can anyone tell me what I should use?? I am confused
wms004
2,864
Los Angeles
May 10, 2004
#12
  • May 10, 2004
  • #12
GM syncromesh
2003BlackStang
188
#13
  • May 11, 2004
  • #13
thanks
wms004
2,864
Los Angeles
May 11, 2004
#14
  • May 11, 2004
  • #14
thanks
I've heard you want to use a non-synthetic Dexron III.. and i believe GM syncromesh was recommended.. Check on the bottle though, to be sure. There are other Dexron III's out there that are cheaper.
-wade
D
DRPURTOP
#15
  • May 11, 2004
  • #15
Tranny fluid
-wade
What does everyone here use in their T45's and how do you like it?
Blev
1,295
So. Cal. V-Town
May 11, 2004
#16
  • May 11, 2004
  • #16
I use Royal Purple ATF and I don't have any problems.
wms004
2,864
Los Angeles
May 12, 2004
#17
  • May 12, 2004
  • #17
I don't have any "problems" either.. but problems now vs. problems you could be creating in the long run are two different things. For those with the Tremec 3650 tranny, using a synthetic as I am right now, I don't have any problems.. but if peoples' rumors from tremec are correct about using synthetics, we could see problems.
2003BlackStang
188
#18
  • May 12, 2004
  • #18
People were telling me the dexron III causes problems thats when they recommended GM Syncromesh. I figured GM Syncromesh is in a Z06 it must be good stuff. Anymore info on would be good thx
85mcLaren
45
#19
  • Jun 6, 2004
  • #19
difference?
Depends on indivdual trans. Supposingly T-5s, etc. aren't suppose to use anything synthetic. It "messes" up the syncro blocker rings. I have used it in some of my T-5s and have no problem. I, however, have one now that is scraping already - only after a year old and have been told to get that synthetic fluid out of their as soon as possible. Seems to be the luck of the draw.
Jason
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
