- Nov 11, 2003
- 188
- 0
- 0
I am that guy. Look at your manual.. it says in the back, Mobile 1 ATF2003BlackStang said:Another thread stated that ford puts MOBIL 1 synthetic in stock is this stuff just crap or is that guy wrong? What should I use and how much any info to help me will be appreciated. Ford is hooking me up with a new tranny and i want to change the fluid first thing so the prob wont happen with this tranny. Thanks for your advice in advance anything will be nice.![]()
GM syncromesh2003BlackStang said:Can anyone tell me what I should use?? I am confused
I've heard you want to use a non-synthetic Dexron III.. and i believe GM syncromesh was recommended.. Check on the bottle though, to be sure. There are other Dexron III's out there that are cheaper.2003BlackStang said:thanks
wms004 said:I've heard you want to use a non-synthetic Dexron III.. and i believe GM syncromesh was recommended.. Check on the bottle though, to be sure. There are other Dexron III's out there that are cheaper.
-wade
I don't have any "problems" either.. but problems now vs. problems you could be creating in the long run are two different things. For those with the Tremec 3650 tranny, using a synthetic as I am right now, I don't have any problems.. but if peoples' rumors from tremec are correct about using synthetics, we could see problems.Blev said:I use Royal Purple ATF and I don't have any problems.
