TFS-2500100
Performance cams need performance parts.
Ford: 289-351W, 1.47 in. diameter, valve spring kit
This kit includes everything you need to install a high performance cam with up to .542 in. of lift on a small block Ford with OEM cast iron heads. It includes valve springs with dampers, chromemoly retainers, valve seals, locks, shims, and a spring height gauge. This kit provides 110 lbs. of seat pressure at an installed height of 1.800 in.
THIS IS FOR A B-303 CAM 1.6 ROLLER ROCKERS? WILL IT WORK? AND WHAT DO I NEED TO PUT THEM IN?
