Will this clear?
  • Thread starter Thread starter ms93gt
  • Start date Start date Aug 3, 2005
M
ms93gt
239
Bayville, NJ
Aug 3, 2005
  • Aug 3, 2005
Will this clear pistons and valves? I have trickflow heads with trw pistons. Cam is comp cam, 224int/230exh, .533/.544 lift, 114 lobe seperation.
Scorcher2005
883
South Carolina
Aug 3, 2005
  • Aug 3, 2005
what are the specs on the pistons? Do they have any relief cuts, are they flat top, domed, what?
84blkstang
544
Springfield MO
Aug 3, 2005
  • Aug 3, 2005
You better clay it up, no one can say for sure because every set up is different, it might but than it might not. There is no way to tell over the internet.
M
ms93gt
239
Bayville, NJ
Aug 3, 2005
  • Aug 3, 2005
The pistons are flat top 4 valve relief. I think they are stock replacement.
Scorcher2005
883
South Carolina
Aug 4, 2005
  • Aug 4, 2005
If they are stock relpacement, i would think the stage 2 would have some clearance issues, especially running 1.7 rockers (you didnt say which ones)
M
ms93gt
239
Bayville, NJ
Aug 4, 2005
  • Aug 4, 2005
I would run 1.6 rockers.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 4, 2005
  • Aug 4, 2005
You have to measure - no one can tell you; rocker ratio probably won't make a huge difference -- mock it up and measure before you swap ratios.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Aug 4, 2005
  • Aug 4, 2005
Max lift occures when the piston is all the way down in the cylinder bore. Duration is more of a telling statistic of p to v clearance then max lift is. I would say if you stay under 230 degrees duration @ .050 you will be ok. But don't just take my word for it... Clay it! I did with my AFR's, and big ol' Comp Cams cam with those pistons, and it was real real close... but it worked.... I think I was a little closer then what people recommend for a "street" application, but it worked.
powertrax91
598
New York
Aug 4, 2005
  • Aug 4, 2005
vristang
4,933
101
124
Seattle
Aug 4, 2005
#10
  • Aug 4, 2005
  • #10
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Wednesday at 6:44 PM
DadLife0724
