will this work, what else do i need
BigHoss91GT
11
hey everyone i have a 91 5.0 ho i have a cold air intake, mass air meter, 65mm tb, edelbrock performer intake, 24lb injectors, msd cap and rotor, msd coil, ford wires, shorty headers, o/r h pipe, flowmasters, 4:10 gears, 125 compucar wet nitrous kit, underdrive pulleys and last a ford f cam. also its an AOD. i was just wondering what to espect ets and also if all of this will work ok together and if i would need anything else for it to run ok.
thanks
brad
If the valve springs in the stock heads haven't been replaced to support the cam, you're likely to have valve float problems. Also, that cam would really like better heads to work with in the first place. I would've stuck with the stock cam unless the heads were replaced with something that works better with that cam. Although the 4.10's help, with the AOD a different stall would be preferred -- ESPECIALLY with that cam.
