Will too many gauges create overload?
88GT17MA
289
I was wondering....if I tap my autometer gauges off of the blue and red wire (the dimming wire)....
How many gauges can I safely connect to this power source without overloading it. Currently Im planning on hooking up:
Speedo
Tach
Boost
Fuel PSI
Fuel level
Oil PSI
Volt
water
Also, the stock cluster will be disconnected.
Thanks in advance
You can crunch the numbers. Watts/volts = amps. Add up the total wattage of your bulbs and divide by 12. Add this to existing demands (accomodating for anything you removed) and see.
If you are doing away with the stock gauges, I'd be reasonably sure you can do it. But without knowing your new bulb wattage, there's no way to know for sure. The dimmer is fused at 5 amps IIRC.
Good luck.
Thanks for the help guys. I think im going to try and use an "add a circuit" in the fuse box, then to a seperate 20A fuse, then to gauge power.
How come it seems most fox owners dont tap into the original fuse box for gauge power?
For powering the gauges, you want a stable power source to help with voltage fluctuations and voltage drop. I'd use an ignition wire (soldered) for it personally.
The add a fuse works ok for dippy stuff but you really don't want that powering something important like gauges.
JMHO.
Good luck.
These are really only to power the small light bulb in the gauges. Pretty much all my gauges are mechanical. I should be ok using an "add a circuit" for this correct?
For the gauge lighting, the add-a-circuit will work.
For an electrical gauge(s), an fuse tap will work but for long-term reliability, I'd just solder into an ignition wire (available under the steering column, for one tap location).
Though not necessary, it's always wise to fuse your new wiring (I believe the add-a-circuit has an integral fuse holder). If not, I always add a small inline fuse on the accessory power and lighting wires, just in case. If all is well, the fuses will never blow. But if your wiring chafes and shorts or a connection comes loose, having the extra fuses are nice.
Good luck.
