Wilwood Master Cylinder
  • Thread starter Thread starter YourBaby'sDaddy
  • Start date Start date Jun 1, 2011
Y
YourBaby'sDaddy
17
SoCal
Jun 1, 2011
  • Jun 1, 2011
I'm installing a Wilwood master cylinder in my '66 coupe. It has 4 wheel manual disc brakes. On the Wilwood master cylinder, the pushrod as a threaded end on it, but nothing to connect the pushrod to the brake pedal. Does anyone know of a place that sells the roll pin eyelet so I can connect the pushrod to the brake pedal? I've seen the adjustible pushrods, but I don't want to take the master cylinder apart if I don't have to. Thanks!
Cupid
162
  • Jun 1, 2011
I'm doing the same thing. Mustang's Plus has the rod you seek. It's freakin' expensive $40.
Mustang Parts from Mustangs Plus :: Search results
Y
YourBaby'sDaddy
17
SoCal
Jun 2, 2011
  • Jun 2, 2011
I was hoping to avoid having to buy that, but so far that looks like the only option. Have you installed yours yet?
Cupid
162
  • Jun 3, 2011
Nope. Currently waiting on a Driver's side FPA header. Then i'll put in the Borgeson box/steering linkage, then i'll slap the Master Cylinder in there. That might be another two weeks.
65wildstang
66
Loretto, TN
Jun 3, 2011
  • Jun 3, 2011
Builder of high quality hydroboost brake systems
Check out this site. They have a large assortment of rod ends that should work for your setup. Good Luck
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
