Window adjustment
01PONY
104
Long Island, NY
On a '03 GT, is there an adjustment to get the windows closer to the weatherstripping? Not up and down, but more like pushing in on the window from the outside. I have a gap pretty much all along the back edge of the window. I did a search and didn't find anything on this. Thanks.
have you ever had the door panel off? Sometimes the window will bump into the Mach460 speaker at the front of the window and untrack it that way (don't ask me how I know this). Also, the little rear wheel on the glass could be off track slightly and also in need of lubrication. Is the window making noise or balky ?
I have the same problem on my passenger side door. When ever I roll it up or down it seems to get off track a bit and have a gap from the wheater stripping. I can roll the window all the way up and push it in but once I roll it up or down again I have the same problem.
Don't know of an adjustment - but I have the gap between the driver side front and rear windows in my vert when I roll down the front window and roll it back up. Gap remains until I open the door and shut it, then the gap is gone. Don't even have to roll the window down/up again, just open/close the door. Weird.
No suggestions, but on the window topic,
when i have my windows partially down (both driver & pass. side), there's a knocking sound comming from inside the door knockin on the glass. annoys me a lot! is the glass off track or something loose inside the door panel? I can actually make it knock on the pass. side by pushing on the door panel at certain spots. :shrug:
guess i could have the dealer take a look at it, but rather would not.
I've just had this problem fixed on my car... For some reason if I rolled the window all the way up and closed the door, the window's top back corner would not seal properly and stick out... I can't explain it.. but I went to a body shop and had it fixed. Apparently, it is very easy and not uncommon.. the window is either of track or the stops are screwed up.
