Window Problem
dcurtis
688
Ok, my drivers side window buttons won't work, and I can't roll down the passenger side with the drivers side buttons either, but the passenger window works fine with its button, I checked voltage on drivers side buttons for both the driver and passenger and got 12.2 volts to the center prong on each switch, I also tried differant switches in it but no luck, I found the window relay switch behind my CD Player:shrug: and took it out and the passenger side window still works from its own button but the drivers side still won't control anything but the locks. Does that mean the relay is bad?:shrug:
There is no relay...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I am also having a similar problem. My driver's side Lock and DS window switches work...but not the DS switch for the Passenger side window. But the pass side window switch works fine...but the pass side lock switch doesnt.
It's retarded. Now that i have that diagram I'm going to take a look at it today!
That link goes to a power window relay, what is that power window relay for?
Convertibles have two extra windows, and have a different circuit with a relay.
Since your information said you did RC cars, I assumed that you knew what the
electronic symbol for a relay was. Look at the diagram and you will not find a relay.
I don't know what that relay is for but, anyways I found out what the problem was, I unplugged my battery and plugged it right back up and my windows now work right again, there are still some pieces of the alarm in the car that are wired in with the windows to roll them up if the alarm tripped or activated, and somehow it activated, in total there are about four boxes for the alarm, 3 small ones and 1 big one, when I roll up the windows with the driver controls I just have to tap the buttons to roll them all the way up, and when they get all the way up something under the dash would tick, looked around for the tick while I was tapping the button and found out the windows wiring has been spliced into the alarm box, even though I thought I had unhooked the main pieces of the alarm.
I guess I am going to go ahead and buy some new remotes for the alarm(didn't have them so I decided to unhook it) and hook it back up so it won't happen again, or I may just pull out the entire thing and make damn sure I get everything this time.
So whats that relay for? I still don't get it I guess:shrug: is it for the converts only, and if so why does my car have it?
Oh, and I think I fixxed the link to the window relay
