window randomly wont work?
  • Thread starter Thread starter jmd2914
  • Start date Start date May 13, 2009
J
jmd2914
937
Napa, California
May 13, 2009
  • May 13, 2009
it started about a week ago and has happened twice. the original time and once after i replaced the switch. the drivers side window will roll down but wont roll back up. the second time it happend i sat there and clicked the button about ten times up and down and it finally rolled back up. im not too good with electrical work so any suggestions//solutions would be appreciated.
thanks
J
HISSIN50
34
129
May 13, 2009
  • May 13, 2009
Does opening the door make it work all of a sudden (or not work)? You might have a marginal wire in the articulated boot in the door jamb.
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
May 13, 2009
  • May 13, 2009
Since it wont go back up, it leads me to believe the window motor is at fault. How old are they? Did you replace the switch trying to resolve this problem?
Fred
J
jmd2914
937
Napa, California
May 13, 2009
  • May 13, 2009
yes thats why i replaced the switch, both the window motors are less than six months old, and opening or closing the door doesnt make a difference.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 13, 2009
  • May 13, 2009
The window motors have a safety clutch in them that consists of 3 plastic rollers. Sometimes the rollers will fragment and the window gets intermittent. Replacement roller kits are in the Help! section of most auto parts stores.
Here are some diagrams of the wiring...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
dubbsix
347
Katy,TX
May 13, 2009
  • May 13, 2009
I just had my passenger side window on my 94GT stop working with the window all the way down. I took off the door panel and use a small hammer and lightly tapped on the motor while holding the up botton and after a few taps, the window went right up. I guess it got stuck or seized.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
No spark. 1990 foxbody 5.0 gt
  • Boogi
  • Nov 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
Boogi
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
