Window switch bezel
I have a 1991 LX 5.0 convertible. I need a drivers side bezel for the power windows. Its NOT the outer bezel that says lock and windows on it. This bezel is 6 inches long, black plastic, and I think was only used on convertibles!! The piece keeps the buttons straight and goes on the outer edge of the power window buttons.
I have checked ALL of the Mustang suppliers and no one seems to have it!!
I glued all of the pieces together the best I could, but I know it will not hold.
It has a Ford number on the inside of the bezel which I think is as follows:
E77B-14A564-BA. The first 2 or 3 numbers may be incorrect.
Is there a website that I can put the original Ford part number from the bezel to locate junk yards who may have this part?
Anybody have ideas on how I can locate this part?
Thanks in advance.
Larry
No not the part that pushes into the switches. If your inside your car looking at the drivers side window buttons, you will see 4 buttons and a lock button. You will see the outer bezel which says lock and windows. You remove those 2 screws and the outer bezel will come off. The next thing to remove on a 1991 LX convertible is another bezel that keeps the buttons lined up properly. (This is the part I need). After you remove the second bezel all you then see is the buttons plugged into the electrical part with all the holes. You would then remove the buttons if you needed to replace the window switch. You can easily remove by using a small flat head screwdriver.
I need the second bezel or the window buttons will have nothing to hold the buttons up. The bezel is 6 inches long, about 2 inches wide and actually goes around the window buttons. This piece also has 2 screws.
Can NOT believe its this hard to find!!!
Larry :shrug:
I need the part on the left. Please note there is a small nipple on each end so the switch can connect to. The picture on the right goes on after installing the nippled part.
Thanks
Larry
