Window wont go back up and its starting to rain
drunkinamustang
53
tx
I got power windows and I rolled it down earlier cause it was hot and sunny, but it wont roll back up, my drivers side will roll up but the other side isnt working, both switches wont work(now its pouring outside and I think god we got a car port)...........So neways how do I tear my door panels off without breakin stuff? I guess the motor went out in it, but i need too get into the door to get the window back up.
:bang:
Your switch panel may be corroded from water, etc. getting down in there. It happened to mine. The window would roll down but I would have to hit the switch 100 times to get it to roll back up. I eventually cleaned it with some electronics cleaner from Radio Shack and the problem went away.
first try bumping on the door with your fist down towards the buttom in the center while holding the button... If that doesn't work you will have to take off the panel and find the motor... With a screwdriver or something tap directly on the motor while holding the button. This should work to get your window up...
Sounds like the first signs of a motor going bad... Once you get it to go up it probably won't act up for awhile but mostly likey it will later on though...
