  • 1994 - 1995 Specific Tech
Windows stop working on my 95
  • Thread starter Thread starter Black Angel 96
  • Start date Start date Jul 5, 2009
Black Angel 96
South of Chicago
Jul 5, 2009
  • Jul 5, 2009
One day my power windows, power locks and power mirrors stopped working on my 95 vert. All the fuses and circuit breakers are good. I took the door panel off, and when I ground everything, the work. So there is power going to everything but they wont work unless I manually ground them. Is there maybe a common module under the dash that they all plug into, or is there something else I am missing. I am lost, and getting frustrated. Thanks.
HISSIN50
34
129
Jul 5, 2009
  • Jul 5, 2009
What do you mean "when you ground everything?"
Some of the items use a floating ground, not a dedicated hard ground. There is a black ground wire egressing the lock switch.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jul 6, 2009
  • Jul 6, 2009
I had my window and door switches start to go bad. Some were working when they wanted, others just stopped all together. If the fuses are good, i'd look at the switches before getting even deeper. Find a junk yard that has 94-04 mustangs...they should let u grab them for free.
Black Angel 96
South of Chicago
Jul 11, 2009
  • Jul 11, 2009
I connected a wire from a bolt on the door and touched the other end to under the window switch. The windows would work then. The same with the locks. Once I touched the wire to the connectors under the switches, the locks would work. I already replaced the switches. It didn't help.
Black Angel 96
South of Chicago
Jul 18, 2009
  • Jul 18, 2009
Nothing still. Anymore ideas?
C
cbrcolt45
41
  • Jul 18, 2009
does the motor even make a sound or no power all together? my window just clicks and i have to help it up and down.
HISSIN50
34
129
Jul 18, 2009
  • Jul 18, 2009
Was the sheetmetal ground in the door in place?
Black Angel 96
South of Chicago
Jul 19, 2009
  • Jul 19, 2009
I hooked up a jumper box to the wire connectors inside the door panel for the windows, and the windows went down, so I know the motor is good. Where is the sheetmetal ground on the door located? Thanks.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
Paint and Body Door Latch Issue
  • KRUISR
  • Friday at 10:38 PM
Fox 5.0 Mustang Tech Today at 3:19 PM
General karthief
For Sale 2006 Mustang GT Shaker 500 Head Unit with Bracket
  • lenko
  • Sep 3, 2026
  • Other Classifieds
Other Classifieds Sep 3, 2026
lenko
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 8, 2026
DadLife0724
