Windscreen Wiper Arm
geordie
576
I'm gradually getting started on my '65 Coupe again. I've removed the front and rear windscreens as the rubber was UV damaged.
How do I remove the front windscreen wiper arms? I managed to get the screen out with them in place but now want to remove them.
I can try and get a pic this evening. Under the arm there is a tab you have to pull out (or is it push in?) to be able to pull the arm off the stud. Years of crud get up in there somehow and it's sorta tough to do, but it should come off with some wiggling and maybe some light tapping.
I just wedge a screwdriver between the base of the arm and the cowl, then pry it off. No tabs on my arms, but alot of 40 year old cars have replacement arms so theres no telling what you might find.
I put a towel on the cowl, then a half inch piece of wood on the towel, and then used the claw end of a hammer and slowly pried up. Worked like a charm; off in about 20 seconds per side.
For my 68 I just wrapped some electrical tape around the jaws of a pair of vise-grips, adjusted the "pinch" carefully and they just wiggled off. LOTS of little wiggling and maybe 30 seconds per. No tabs, no wedging.
I just wanted to point out that there is a proper tool for removing the wipers. It clips on under the ball and helps you to wiggle it off.
I have used a screwdriver with great success throughout the years under the ball before by prying on the section directly away from the wiper blade. Of course you need to place something on the cowl to protect the paint/body.
SoCalCruising said:
Windscreen wiper arm? Where are you from?
He aint from Californ-I-A!
My guess is the UK or a commonwealth thereof :D
British term to American term
accumulator= battery
actuator= switch or servo
Artic= articulated lorry is a "tractor-trailer"
baulk ring= synchro ring
bonnet= hood
boot= trunk
bulkhead= firewall
choke tube= venturi
core plug= freeze plug
crocodile clip= alligator clip
crosshead= Phillips
crown wheel= ring gear
cubby box= glove box or glove compartment
damper= shock absorber
drive shaft= half shaft or axle shaft
drop-head coupe= convertible version of 2 door coupe
dumpy screwdriver= short screwdriver
dynamo= generator
earth= ground
estate= station wagon
fascia= dashboard
fixed-head coupe= 2 door coupe
frogeye= bugeye
Gallon (Imperial)= 5 US Quarts
gearbox= transmission
gudgeon pin= wrist pin
hood= convertible top
jointing compound= gasket sealant
lorry= truck
mole wrench= Vice grips
monocoque= unibody
MO= DOT
Ministry of Transport= Department of Transportation
nave plate= hubcap
nose= front of car
paraffin= kerosene
pinking= knocking or pinging
prop shaft= drive shaft
petrol= gasoline
prise= pry
proud= above or raised
quarterlight= vent window
rev counter= tachometer
ring gear= flywheel gear, or starter gear
roadster= car that only comes in a convertible style
roundabout= rotary, traffic circle
RoStyle= type of steel wheel (as opposed to wire)
saloon= 2 or 4 door sedan
scuttle= cowl
side curtains= removable side windows
silencer= muffler
sill= rocker panel
Shooting Brake= station wagon
spanner= wrench
split pin= cotter pin
spring washer= lock washer
squab= part of seat
suction advance= vacuum advance
sump= oil pan
thrust bearing= throwout bearing
tickover= idle
top gear= high gear
torch= flashlight
trunnion= sliding or rotating joint (suspension)
Tyre= tire
wheel nut= lug nut
whitworth= Brtish thread measuring standard
windscreen= windshield
wing= fender
Well, I took a couple pics of the wiper ends I have. This was the least blurry, sorry, but the digi cam has a problem I can't figure out.
Numbering them from the bottom to the top 1 thru 5, #2, #3 & #5 are the same but #3 is missing it's metal tab. #1 is similar, but doesn't have the flange around the base, #4 doesn't have the flange, but the tab is on the outside. All of the wiper arms shown are Trico brand, I don't know if they were OE suppliers or if they're all replacements. I believe #2 & #3 came off my Mustang and the rest came with a parts car I bought.
I usually take a small flathead screwdriver and put it between the tab and the post and then work the wiper off the post.
Cannonball888 and SoCalCruising, to answer your question, I'm originally from the north east of England, however, I've lived here in AZ for the last seven years.
1320Stang, thanks for the photos.
Sorry, I meant a "Mole Wrench".
