WINDSHEILD WIPER ISSUES...MORE HELP
  • Thread starter Thread starter DROPTOPFIVEOH
  • Start date Start date Nov 3, 2009
D
DROPTOPFIVEOH
11
  • Nov 3, 2009
The previous owner of my car was having wiper issues before i picked up the car. I replaced the wiper motor and the wipers now move but when the interior switch is placed in the "o" position(off) the wipers keep going. I assumed the interior switch may be broken so i got a used switch from the same friend who gave me the wiper motor and still no change in the problem. The switch was out of a 91 5.0 lx and the wiper motor is a 2 plug out of a 89 or 90 notch back. Does anyone know whats wrong with this thing????...Im starting to loose hair from this stang..... lmao
I would apprecciate any help guys.....
Thanks
Adam
D
DROPTOPFIVEOH
11
  • Nov 4, 2009
has no one had wiper problems??? am i the only one ??
Chrome_Rust
530
Findlay, Ohio
Nov 4, 2009
  • Nov 4, 2009
the wipers work by multiplexing. Meaning different voltage values control different things. There is a module under the drivers side of the dash that controls the wiper motor. It is bolted to an A frame shaped mount. I think it is grey. I think I have the one from my 93 somewhere. I swapped in a 01 dash and had to swap the module to work with the newer resistance values in the turn signal stalk. I will give you the old one, cover shipping.
Posted via Mobile Device
RYC CUKR
1,437
Orlando
Nov 4, 2009
  • Nov 4, 2009
I had issues with my wipers once and it turned out to be the intermittant control module. The gray box described by Chrome. I pulled one out of the JY and all is good.
BlackGT89
774
Huntsville, AL
Nov 4, 2009
  • Nov 4, 2009
I had the same problem with my wipers a while back, they just did not want to turn off. Very embarrasing ! I replaced the motor and the problem was solved. I think I remember someone here saying the park feature is inside the motor. It can also be many other things as have been mentioned.
D
DROPTOPFIVEOH
11
  • Nov 4, 2009
PROBLEM SOLVED
I GOT THE PROBLEM FIXED GUYS IT WAS THE WIPER MODULE THAT IS MOUNTED UNDER THE COLUMN AS THE OTHER TWO GUYS MENTIONED. I BORROWED ONE FROM MY DAD'S 92 LX AND FIXED THE PROBLEM. I LOCATED ON AT A SALVAGE YARD THAT I CAN GET FOR NOTHING. GOING TO PICK IT UP TOMM THANKS FOR THE HELP GUYS ..... IM GLAD THIS PROBLEM IS GONE...
THANKS AGAIN
ADAM
J
Wipers won't work at all
  • jpfox
  • May 8, 2025
Fox 5.0 Mustang Tech May 16, 2025
nickyb
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
J
Help! 78 II has no power to any electrical except headlights and taillights and hazards.
  • JackH
  • Jan 8, 2024
  • 3 4 5
13K
1974 - 1978 Mustang II Talk & Tech Mar 28, 2024
M
Window issues
  • Meierznutz
  • Jun 25, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 28, 2024
AeroCoupe
